Hi,
When starting the car most the time I need to use the accelerator to start it.
It's had new leads, plugs, oil, oil filter, battery. What else could be causing this? Or is there anything I can try to get to the bottom of it?
starting issues
bobbin1982
Have you cleaned the throttle body by taking the rubber boot off and spraying some carb cleaner through it?
You need help with this so someone can rev/idle the car while you spray it
Have a Mk3 golf which does similar things as this and it normally fixes it for months
Andy
Andy
Driving my digger!!!!
