Hi there quick question regarding e30 hubs
I'm thinking of purchasing a set of second hand bc racing coilovers with hubs mounted as I believe they are welded in order to fit these coilovers.
The car they are coming off is a 325 and I have a 316, so my question is can I fit these hubs to my car without any problem?
Are all hubs the same on factory e30's and the only difference being the diameter of strut with the 325 and the M?
Cheers Tom
E30 hubs
All four bolt E30 hubs are the same, give or take an ABS ring.
Large and small diameter struts are interchangeable with the appropriate sized damper.
Tomo_e30
Thanks for reply mate, well notedBrianmoooore wrote:All four bolt E30 hubs are the same, give or take an ABS ring.
