Mk3 golf
bobbin1982
Tue Sep 13, 2016 9:21 pm
Ok all i know i know its a VW!
But what i would like to know is how and if i can adjust my camber at home?... A garage changed some suspension components for an M.O.T and now the camber is out and when i do left hand turns the tyre squeels as if im doing 110MPH when im doing 12MPH
Any help will be appreciated as this will be my daily driver again very soon when i take my E30 off the road for a good going over a bit of welding some paint and a few goodies!
Hopefully i can sort it out myself so i dont have to take it to a garage to sort the problem and break something else!
Cheers , Andy
Driving my digger!!!!
ross_jsy
Tue Sep 13, 2016 9:33 pm
Are you sure it's the camber that is out? That isn't adjustable. For the camber to be out (assuming stock top mounts) that would suggest something is bent.
Are you sure you don't mean tracking?
Tue Sep 13, 2016 9:40 pm
Chassis notch FTW :D
bobbin1982
Yes all stock parts it a GTI if that makes any difference?
I was told its camber by a friend and also when i look at the wheels it looks like they are different angles? maybe something is bent but wouldnt that come up on an M.O.T (assuming its a legit one?)
Would Tracking cause the issues i mentioned?... If so can i adjust that or would i just be better off by getting it done professionally?
Andy
ross_jsy
Tue Sep 13, 2016 9:43 pm
Tracking could cause a wheel to drag. It would also handle horribly.
You can do the tracking yourself. Google string line tracking method. Last time I did it it was 0.05 degrees out total over both sides when I took it to get tracked the next day.
I would take it to get the tracking/alignment done properly. What parts were replaced?
bobbin1982
Tue Sep 13, 2016 9:50 pm
Cant remember what parts where replaced as it was last year and lost the receipt!! it wasnt anything expensive so thinking control arms or something
Ill get the tracking done anyway as its only about £25 quid thereabouts
Dan whats this chassis notch you talk about?
Andy
ross_jsy
Tue Sep 13, 2016 9:57 pm
It's a dub thing :D
bobbin1982
Tue Sep 13, 2016 10:06 pm
OK :mad:
Looked this chassis notch thing up and find its when people drop the car and such they have to make a "Notch" to compensate?
My car is on standard suspension!
bobbin1982
Tue Sep 13, 2016 10:15 pm
and when my car went in it was fine and didnt do the screeching!!
M3Pete
Tue Sep 13, 2016 10:44 pm
There is a fair bit of adjustment with the slop in the strut bolts. A tracking place that knows vw's will be able to sort this.
scottybeemer
Wed Sep 14, 2016 12:30 am
bobbin1982 wrote:OK :mad:
the notch is too allow the driveshaft to go higher without hitting the chassis leg
"you aint gonna take me alive, copper"
scottybeemer
Wed Sep 14, 2016 12:31 am
probs just need tracking done
bobbin1982
Wed Sep 14, 2016 5:55 pm
ok ill try that then cheers all
powelly
Sat Sep 17, 2016 11:24 pm
The bolts that hold the suspension strut to the hub assembly are slotted, VW have a special tool that attaches to the strut and the wheel rim if I remember rightly. If I were you I'd get a VW specialist to do the alignment.
Image Le Mans Classic 2006
