I have the token fault in the cluster on my 94' 318i Touring (UK).
The fuel gauge and speedo are completely dead, I mean six foot under. No flickering or attempt to work and it's been like this since I bought her. Ive never seen them move a millimetre even with the miracle "punch"
The temperature, rpm and economy guages all work fine, even the odometer works still.
Now I have tried nearly everything I can find online to fix it including:
New ground nuts and re-soldered ground point.
Brand new batteries soldered into SI board. (Both working)
All solder joints checked everywhere and re-soldered on the SI board and the cluster PCB (board is in surprisingly good condition)
I have checked the sensor in the diff for the speedometer and it was fine however I replaced it anyway.
Fuel sender units seem okay no corrosion evident.
So now I am unsure of where to turn or what to do. Trawling through the forums has unfortunately yielded nothing as of yet. My hunch is maybe its a wiring problem to the cluster but I wouldn't know where to begin.
Any ideas or shared experience is more than appreciated, ta lads.
