manifold
MACKEROOE30
evening guys probably been asked before , but what are the problems with trying to fit lhd manifold to an IS ...thanks John
Overlaps the space already claimed by the steering shaft.
MACKEROOE30
Thanks for quick response , have a guy over here recons he can alter it to fit do you know if that is possible
MACKEROOE30
Metal can be bent, metal can be reshaped, and metal can be cut and rewelded, so it's possible. I have no idea how much interaction between steering and manifold there is in this application, so I can't comment on whether it's economically viable or not.
Before you go ahead, you ought to consider whether you might want to upgrade to a faster E36/46/Z3 steering rack at some time, which will move the steering shaft's position, and make a manifold modified for an E30 rack useless.
MACKEROOE30
Thanks Brian will have to give it some though
