Hello all
Firstly I have small feeling that the head gasket has gone on my m50 engine, which I will investigate at the weekend, but I was thinking if the head does have to come off is there any point in porting and polishing these heads ? Or are they pretty good as standard ?
Also I'm going to do the flywheel and clutch swap back to the e30 325 clutch and flywheel but I need the release bearing, does anyone have the part number for it ?
Thanks in advance
M50b25 head question and e30 clutch question
Tedswagon
Porting and polishing is not really worth it on its own. You would be better upgrading the cam shaft.
Benjer182
Ok mate thank you for your input, is the a cam you would recommend?
