aftermarket ECU wiring
Shaheenk
Post Sat Jun 11, 2016 9:55 pm
HI guys
I need some help please
I am wiring an aftermarket ECU into my E30 , reason being I have a turbo and need more control and fuel .
what I have done is cut off the ecu connector from the Motronic unit in a hope to wire my aftermarket ECU into that .
I need to know the following.
My Aftermarket needs 12= Ign , I assume this is pin 27 or 37 on the motronic.
I also need to know.....
1. Which pin Goes to the coil -ve
2. Which pin is Coil +ve
3. Which pin is injector +ve
4. What does pin 36 do and does it need +ve or -ve
5. Does the output to the fuel pump relay need -ve switch or +ve switch
On the input side ,
I need to wire the CPS in , which pin is that .
My aftermarket has +12v which says +ve for injectors. but I cant see motronic having +ve in injectors. or does it get this from a relay or the harness.
maxfield
Post Sat Jun 11, 2016 10:07 pm
Shaheenk
Post Sat Jun 11, 2016 10:45 pm
yeah been through that , seems I don't need to wire the positive from my ecu to the injectors, but I do need to figure out how to switch the dme relay on...
gromgsxr
Post Sun Jun 12, 2016 12:11 am
Yeah you do... you can build a simple transistor circuit to do this with a transistor a resistor and a diode or wire up a second relay to ground the main relay in the engine bay and power everything up. the relay option sucks though as if the battery is a bit low you can lose power to the injectors and icv during cranking and it can be a mare to start the car like that.
transistor connections.
1 The Emitter (2n2222a) connects to ground
2 The Base (2n2222a) connect to pin 27 with a 7.5k ohm resistor
3 The Collector (2n2222a) connects to pin 36
4 The 1n4001 diode connects to pin 18 and 36 with the banded end towards 18
Shaheenk
Post Sun Jun 12, 2016 9:14 am
mmmm, ok, I found a tread which talks about getting the DME relay to power on with the key, would this not be a better option, My aftermarket has a number of 12Voutputs and a few switched grounds as well .
gromgsxr
Post Sun Jun 12, 2016 11:30 am
the dme relay powers the ecu on pin37 i dont think your after market ecu will be able to provide a ground output to turn on the dme relay, if the does not have power its self.
iv been using the transistor circuit for about 3 years on my ms3 and works great.
Shaheenk
Post Sun Jun 12, 2016 2:25 pm
you sir are correct, I will build the required transistor circuit to power the main DME relay .
thanks
