BMW E30 MS DIYPNP KIT
mincedbeef
Post Tue May 24, 2016 12:21 pm
Who on here has built their own kit?
I'm nearly done with it just a bit confusing as to what to do with the last few pins on the board. OP+, OP-, VR2, IAC.
Does it look about right
gromgsxr
Post Tue May 24, 2016 6:51 pm
not built one but would guess, op+ & - are for optoisolator input for triggering off a coil negative so can be left alone, vr2 would be a second vr input cam sensor ect thats the lm1815 circuit on the board, iac is usually for stepper type idle motors, are you using the stock idle valve as thats a pwm type valve.
3 bips wasted spark?
mincedbeef
Post Tue May 24, 2016 9:06 pm
Yeah plan to use the stock idle valve. yes running wasted spark, I've got a GM coil pack coming this week
gromgsxr
Post Tue May 24, 2016 9:39 pm
did you fit the 18k resistor in-line with the vr+ wire and set it up to trigger the main relay? are you fitting a variable tps to the car? and have you done the jumpers for the 3wire pwm valve?
