Rear arches???
gnrsoul
Would 2 door replacement rear arche panels fit on to a convertible as can't find any for cabby??
andysheep
I used two door rear panels ,but its a lot of work
is it roting out at the top of the arch?it was a while ago but i think its a pre face lift rear arch,and a bit of sectioning,the old time verses money
gnrsoul
To be honest there not that bad it's just starting to rot around the lip all other parts are fine I am restoring my car and just thought of doing it so there was no chance would need to do it later on after a few years down the line might see if they can be repaired but good the know I can use them cheers
andysheep
Better to hit it before its a inner and outer job!expensive and a ball ache
hope it goes ok,and double check its the preface lift panel,before you buy,like i said its a while ago and i just cant remember.
Andy
Andy
