325i exhaust too quiet
ccaallvviinn
Post Thu May 12, 2016 6:57 pm
My recently purchased 1990 325i has a standard exhaust, and unusually a cat (factory ordered)
I'd like it to sound a little fruitier, but still look standard ish, and not sound like a boy racer
Any advice?
Post Thu May 12, 2016 7:17 pm
Remove the cat., knock seven bells out of its insides, pour the debris out, and refit.
Will probably increase the noise level, and will definitely improve the MPG.
Post Thu May 12, 2016 11:46 pm
After removing the cat, disconnect the O2 sensor and check/adjust the mixture to 1.5 CO (as long as rest of the engine is working as it should be with correctly adjusted valve clearances)
maddogg
Post Mon May 16, 2016 10:29 am
If its a genuine BMW one in good condition I may be interested in it
Post Mon May 16, 2016 4:36 pm
Leave it alone. It's how BMW intended it to sound.
