Rev counter trigger location
Orangecab
Post Tue May 10, 2016 8:03 pm
Hi, haven't been on here in about 6 months and haven't touched my car in about as long!
What I'm after if anybody knows is where does the Rev counter on a 6 pot get its trigger from? As I will be fitting a non Bmw engine and wanted to know if I'd need to make a trigger on the crank pulley etc
Tia rob
gromgsxr
Post Tue May 10, 2016 9:48 pm
on the later cars the tacho is driven by the stock ecu, its a 12v square wave signal one pulse per ignition event.
Orangecab
Post Tue May 10, 2016 11:24 pm
What about the early model? As I can change bits and bobs around to suit, any idea how to make the Rev counter work on a v8 carb engine to e30 clocks, either early or late clocks as I assume they are interchangeable!
