where do these wires go?
Finto_316
Doing engine conversion from 320i to 325i. I've put battery in boot with genuine kit. But I can't seem to figure out where these two wires go . one is on starter loom, not sire if its for starter as there's already two wires on starter. Other wire comes out of bulkhead.theres two wires together with same ring connector on end.Not sure if an earth or for positive connection on terminal.
BMW e30 325i Sport-88-Diamond Shwartz
Finto_316
Won't let me upload photos!!
What are the colours of the wires? They may have a black outer sheath.
Finto_316
Small one ran to top of starter. But the two together are an earth but I don't know where abouts it earths to. Car runs with it earthed. Didn't check colour but the two wires are shaped to earth at same point.
If you want the wires positively identified, I need colours.
Yeti
i just wired up a 325 lump mate take a photo of the wires and where they are i should be able to help you
Finto_316
Brian. The wires are wrapped in black factory core. In one of wires there are brown and orange and brown and yellow. In the other wire is just all brown and about 4 or 5 wires.
Finto_316
. Any ideas Brian?Brianmoooore wrote:If you want the wires positively identified, I need colours.
What are the ages of both the car and the engine that's gone into it?
