Brake light check light lit but break lights are ok.
Doobit
Post Sun May 08, 2016 8:28 am
I have an intermittent fault when the break light check warning light comes on, but the break lights are ok.
Anyone have any ideas what this could be. Is it worth just changing the bulbs?
E30 325i Cabriolet Alpinweiß chromie
F12 640d
G11 730d
Post Sun May 08, 2016 2:51 pm
Common cause is an incorrectly adjusted brake pull rod - one of the few adjustments that needs to be made occasionally on an E30 to compensate for wear.
If the brake pedal has dropped far enough so that the brake light switch is on the point of putting the lights on, the lights will flicker on over pumps, and this can trigger the warning light.
Doobit
Post Sun May 08, 2016 8:45 pm
Thanks Brian. I've checked the break pull rod, seemed OK I tightened it a bit, but the fault is still there. Does the fact that this happens most often when I start up and the car is stationary, then it goes away if I hit the break pedal make any difference to what you think it could be?
F12 640d
G11 730d
Post Sun May 08, 2016 9:16 pm
Doobit wrote: Does the fact that this happens most often when I start up and the car is stationary, then it goes away if I hit the break pedal make any difference to what you think it could be?
Yes, that does make a little difference! That's exactly what it's supposed to do - put the LED on at start up, then extinguish it the first time the brakes are used, if no fault is present.
Doobit
Post Sun May 08, 2016 10:23 pm
Thanks Brian, next time I'll read the manual properly!
F12 640d
G11 730d
