Tick tock sound and electrical wobble
ccaallvviinn
Post Sun May 08, 2016 7:36 am
Sorry chaps, being new to e30 I afraid I have quite a list of questions I've not been able to find answers to.
On starting the car, there is a 'tick tock' from the dash that coincides with the temp gauge flickering and the alternator belt squealing momentarily suggesting two jobs need doing, one of which is a new ancillary belt . What is the 'tick tock' and is it normal.
Thanks a lot
Post Sun May 08, 2016 2:39 pm
ccaallvviinn wrote: What is the 'tick tock' and is it normal.
No idea and no!
I suggest you sort the belt out first and go from there.
Flickering temp. gauge can be a loose not on the back of the cluster, but in your case could also be related to the slipping belt.
aimlessrock
Post Mon May 09, 2016 2:17 pm
water pump?
E30 320i Convertible (1989)
190 Mercedes (1988)
Pinchy_Larou
Post Mon May 09, 2016 2:31 pm
Tick tock maybe a relay switching but for what, I've no idea (not much help at all I know) :?
ccaallvviinn
Post Mon May 09, 2016 4:43 pm
Yes, it does sound like a big relay, as he car warms up it gets let frequent and then stops, I suspect that it's drawing a large load which is making the alternator work hard which squeals the belt, mystery
Post Mon May 09, 2016 7:27 pm
Only relays behind the dash are up to three low down on the extreme LH side, and none of these are likely to be switching on their own at start up. Two more relays inside the bottom of the A pillar on the RH side, but these can't draw enough current to slip the alternator belt.
Any alarm/immobiliser module will also contain two relays, but if the engine's running, these won't be doing anything either.
What car is this, BTW.
Edit: Possible lightbulb moment. Is the heater fan switched off? Thermal overload in the heater resistor pack can cycle slowly if it detects an overload or is faulty.
ccaallvviinn
Post Mon May 09, 2016 9:08 pm
Ahhh, that's a point, the fan is faulty so it may be left in the on position, I'll check in the morning, thanks so much for your help
ccaallvviinn
Post Wed May 11, 2016 9:19 pm
Well done! All related, fan in off position tick tock stop! Thank you
