Post
Sun Jan 22, 2006 10:22 am
Think that aircon set up was dealer retrofit rather then aftermarket, but may be wrong.
No obvious connection between the rear wash/wipe and the front fogs, so you might be right about the switches. They can be dismantled and cleaned easily enough, or just switch cleaner sprayed in from the front beside the buttons followed by vigourous working of the buttons may work.
