http://www.ebay.co.uk/itm/BMW-V8-M60-M6 ... Sw-vlVnMtq
Anyone know anything about these ?
Many thanks
M50 gearbox to m60 engine
chu346
What do you want to know?
Make sure they work with RHD engines, most don't
chu346
I asked what else is needed to fit to a M62 engine with the kit below
http://www.ebay.co.uk/itm/BMW-V8-M60-M6 ... 1843496844
This is the answer
This is the answer
You obviously won't have to move the crank sensor on the M60 engine.Hello,
Adapter works with M62 engine, but haven't the place for the timing sensor on the ring gear. In case M62 You need to move the sensor into the front of the engine like in the M60 in standard. After this You need some singlemass flywheel with spacer about the adapter plate thickness or my light flywheel designed for this conversion. Complete kit adapter plate and flywheel with all screws is for about 680 euro + shipping to You
