Hi,
I have noticed my fuel lines (the rubber pipes in the engine bay that attach to the fuel rail - in and return) are starting to perish.
I'm swapping the engine in a couple of weeks, so while I'm doing that I want to change the rubber pipes.
Can anyone tell me the size of pipe plus how many meters I will need, please? If you know a supplier too that would be a Brucie Bonus
Thank you for any help.
What size fuel lines?
BackinBlack
8mm x 13mm. How much you need depends on what car and what engine.
Genuine BMW hose lasts longer than aftermarket stuff.
BackinBlack
Hi Brian, thanks for coming back about the pipes.
I've got a '90 cabbie currently with a 2.0, but I am putting in a 2.5
Engine change will make no difference to the amount of pipe you need - fuel hoses for the two engines are identical for post facelift engines.
biffer
2 metres was enough for the underbonnet ones on my 2.5
BackinBlack
Thank you guys for the information, much appreciated.
