I obviously need to retain a lot of the motronic engine loom and the ecu, but i'd like to remove some of the surplus wiring, hopefully without losing the ability to make sparks
So does anyone know which sensors the ECU uses to calculate ignition timing/advance.
I know the crank speed/pos sensor is needed, which is wired direct to ecu
things i'm not sure about:
throttle closed/wide open signal
coolant temp
air inlet temp from AFM
other sensors I've forgotten.
From the motronic diagram in the haynes it looks like i can remove the injector wiring, fuel pump relay with all wiring and the main AFM unit.
