Propshafts
- Brianmoooore
The rear sections of of E30 propshafts are all the same length, but the front and rear parts are balanced as one, so if you change the front half for another one, the assembly will need balancing.
The balance needs to be accurate, because of the design of the centre bearing mount.
- Brianmoooore
M3 prop. will be unique, if for no other reason than it uses a larger guibo than other E30s.
- Brianmoooore
A universal joint, running at an angle is NOT a constant velocity joint - with the input shaft turning at a constant speed, the output shaft continually accelerates and decelerates slightly as it turns. This is largely irrelevant, because when this eccentric motion reaches the second universal joint in the prop, the opposite happens, and the rotational motion is converted back to a constant speed again, provided that the extreme ends of the prop. are parallel with each other, and it has been assembled with the two universal joints lying in the same plane.
Assembling a prop. with the two white dots in line (or 180 degrees out) will achieve this, but that is not the same thing as balancing, and two halves of a prop. from difference sources, will not be properly balanced, except by possible coincidence.
It's possible do do a DIY balance job with two large jubilee clips clamped onto the prop. side by side. When the two worm drives are positioned together, it will have the maximum effect, and when the worm drives are opposite each other, they will have no effect.
Demlotcrew
Pretty sure the bearing is on the rear section of an e30 M3 prop and the regular E30's have the bearing on the front section. So not compatible......
Demlotcrew
What is the damage?
Demlotcrew
I see
Yup. 325i top, E30 M3 bottom...Demlotcrew wrote:Pretty sure the bearing is on the rear section of an e30 M3 prop and the regular E30's have the bearing on the front section. So not compatible......
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
Demlotcrew
Must save that photo as I couldnt remember 100% which way round the configuration was
