Locking Nuts (vs Bolts)
JungleGus
Post Wed Apr 06, 2016 11:40 am
I am running wheel studs instead of bolts, are there any locking nuts you can get that will match the right angle for a BMW wheel?
I guess my other option is to remove a stud and use the locking bolt...but any suggestions appreciated!
Cheers,
Gus
Theo
Post Wed Apr 06, 2016 12:05 pm
Yes you just need M12x1.5 locking nuts with a 60 degree taper.
Post Wed Apr 06, 2016 1:50 pm
The thread in most locking wheel nuts is 'blind', so ensure that the nut will screw on far enough, with any wheel that you may use, without starting to 'bottom out'.
JungleGus
Post Wed Apr 06, 2016 1:54 pm
Yeah - haven't been able to find anything that would work just yet.
Looks like locking bolts are going back on!
Theo
Post Wed Apr 06, 2016 3:42 pm
Do your wheel studs protrude by a particularly large amount then?
JungleGus
Post Wed Apr 06, 2016 4:26 pm
Yep - they are the Turner MS bulletnosed ones. I can't get the centrecap on either. Slightly annoying...
