Mishimoto Rads for M60B40 Conversion
gooseygander110
Anyone have any idea about which Mishimoto rad is best for this conversion........ Have a 535 in at mo and after the last track day .....needs upgrading .......anyone using one ?!!
maggspower
- Turbo Farmer Tractor Driver
Their e36 m3 rads will fit, if you use two of the small plastic feet for the bottom.
You'll have to make a custom mount for the top. Easy enough though.
Contact: theengineshedonline@gmail.com
jimbom30cab
- Tech 1 freak
Another vote here for the e36 m3 Mishimoto rad
http://www.e30zone.net/modules.php?name ... &start=325
M20 top mount kind of fitted ok
Worth getting the 68 degree stat also
They come with a life time warranty , even if you crash the car !
When the 16" fan turns on, you can actually see the temperature gauge falling back.
Im using a chinese M3 size aluminium radiator, it was about £140 5 years or so ago, never had a problem. It looks exactly the same as mishimoto rads (some of the welds are better actually on the one I compared) but with less paint/warranty
gooseygander110
Thanks guys ....... I think i'll go for the Mishimoto one Jim .....any idea on where to get a 68' stat for the M60b40 ? Cheers
jimbom30cab
- Tech 1 freak
You can get the stat from the mishimoto web site mate
gooseygander110
Cheers Jim , I see them ..... Am waiting on a call to see if they will fit
