Timing belt and water pump.
Bazo187
Wed Mar 23, 2016 4:20 pm
Changing the belt at water pump for the
First time.
Do I need to go for any specific brands?
If so what is the best to go for?
pierce
Wed Mar 23, 2016 5:48 pm
I've always used gates.
Mr-Lachs
Wed Mar 23, 2016 7:14 pm
Gates for me too.
Mr-Lachs
1988 BMW E30 325iSE Auto, 4 Door, Lachs Silver (Fair Weather Machine)
2012 Vauxhall Insignia 1.8 Exclusiv, Technical Grey, (The Daily)
Andyboy
Alpina Colada
Thu Mar 24, 2016 12:47 pm
Gates or Contitech.
Silverfang
Fri Mar 25, 2016 5:29 pm
When putting the water pump in, do use a smear of blue hylomar (silicon) on the gasket, the paper gasket doesn't always seal first time and you'll be pulling it apart again.
Also when changing the timing belt, once the old one's off, crank the cam pulley a half tooth clockwise to seat the belt in the tooth groves, once it's seated crank the cam back to TDC. It'll mean you get the belt tension spot on. Did this on my 320 and 325i and never had an issue unlike when a garage did it and didn't tension the belt properly.. jumped 6 teeth and 6 exhaust valves later.. :roll:
BMW and Opel, both RWD, both german, both good fun
http://www.clockservicing.co.uk/ For any clock repairs try here.
Bazo187
Fri Apr 01, 2016 9:57 pm
Sorted
