Electrical issues upon re-energising after rebuild
jimbom30cab
Tech 1 freak
Post Thu Mar 17, 2016 9:54 pm
I've got a feeling this is an earth problem !
325i 1987 prefacelift.
So i've energised up today after a bare shell resto and have the following issues:
- Front indicators not working - the rear and side work and bulbs are good. The rear brake lights go dim and bright in sync with the indicators.
- Front fogs not working - rears also not working and no fog light indications lit on the dash panel. All bulbs checked good.
- OBC not energising at all.
- No heater fan
I'm thinking i've got a bad earth behind the glove box ??
There is a single earth wire connected at the G104 behind the left headlights, and it's a good clean earth. Should there only be a single brown here? (i've not connected up the HHLW yet)
Any ideas?
Many thanks
BenHar
Post Fri Mar 18, 2016 10:12 am
jimbom30cab wrote:I've got a feeling this is an earth problem !
Clean the switch?
jimbom30cab wrote: There is a single earth wire connected at the G104 behind the left headlights, and it's a good clean earth. Should there only be a single brown here? (i've not connected up the HHLW yet)
Haven't you got another car to look at?
Ben
jimbom30cab
Tech 1 freak
Post Fri Mar 18, 2016 10:38 am
Yer but it's not pre-facelift Ben, i'll have a look anyway. Thanks
biffer
Post Fri Mar 18, 2016 11:18 am
my car's a tech1 and it had 2,maybe 3,wires to the earth behind the headlamp.
i also had no foglights after a restoration-dismantelling the switch and cleaning the contacts sorted it.
jimbom30cab
Tech 1 freak
Post Fri Mar 18, 2016 12:04 pm
Thanks guys guess I was really tired last night !
Indicator bulbs just needed a wiggle
Fogs was just duff switch, both actually which I was surprised with
Happy days
