Hi am a swapping a 2.0 auto for a 2.5 switchable auto.
Is it a straight swap of engine and boxe. If not then please can you let me know what else needs changing. 2.5 has the sport setting. new to all of this so any help is appreciated.
Regards Ahmed
Swapping a 2.0 for a 2.5 help please??
Topblag
Switchable auto has an ECU in the boot, behind the trim the jack sits on. Also prop shaft is a different length and I assume the main ECU will need changed also. You'll need the handbrake console with the switch for the interior and you may need some extra loom sections to tie it all together. I think the interior selector may also be different as I think all switchable have a cable selector instead of a lever.
You'll need a different diff ratio to do it properly.
1984 Hartge H35 in Black
2006 Audi S6 V10 in Black 58k
Topblag
If it's not a cabby or touring, you'll need front struts, dampers, ARBs, springs, possibly rear disc conversion - there's probably more....
- cory58
Why would those front suspension parts not work with an M20b25?Topblag wrote:If it's not a cabby or touring, you'll need front struts, dampers, ARBs, springs, possibly rear disc conversion - there's probably more....
1992 325i Cabrio
1988 320i Touring
2015 328i
2001 325i (R.I.P.)
1988 320i Touring
2015 328i
2001 325i (R.I.P.)
