E38 m60 wiring loom.
padi
Post Sat Mar 12, 2016 10:24 am
Hi guys,
As some of you are aware I've been slowly building an m60b44 and I need some advice on wiring looms. Has anyone done the e30 m60 swap using the e38 engine loom? They seem to be different to the other m60 looms in that they don't have the x20 connector on the head part, to connec to the body? Has anyone managed to get around this? Or do I need to use the e34 540 loom?
Any advice would be great.
Cheers Chris.
woodye30
Post Fri Nov 18, 2016 6:08 am
Hi, i have the same problem, you have the square white 12 pin connector?
have you done the wirring?
