I am getting fed up of having multiple keys on the daily. Am I correct in saying BMW will be able to provide me a key full set of barrel pins for each lock when provided with the VIN number?
Ross
Key sets
ross_jsy
£200 will buy you a new lock set
Or dependant on what you have, one lock repair kit will enable you to match both your door locks to your ignition key.
maggspower
- Turbo Farmer Tractor Driver
£200 is not that bad, its £80 just for the ignition barrel for my van. Needless to say I have been using a screwdriver for some time nowpacerpete wrote:£200 will buy you a new lock setOr dependant on what you have, one lock repair kit will enable you to match both your door locks to your ignition key.
Contact: theengineshedonline@gmail.com
