wild chip m30b35
jurassicwadey
Mon Feb 22, 2016 10:00 am
Have a wild chip installed on my m30b35 and wondered if it is causing problems when cold?
when the car is warm/hot the car drives perfectly, but upon first start it will tick over fine, but hit the go peddle and it seems reluctant and spluttery, until the temp gauge gets out the blue then its perfect?!!
is this just a wild chip thing?
Bristol_Jer
Mon Feb 22, 2016 6:20 pm
I've got one of those chips in mine and it's always been spot on, even straight from cold. How long has the chip been fitted to your car for?
Mon Feb 22, 2016 7:31 pm
Check the blue temperature sensor and wiring first before condemning the chip!
http://www.e30zone.net/e30zonewiki/inde ... emp_Sensor
pianist
Mon Feb 22, 2016 8:53 pm
does sound like temp sensor fault
jurassicwadey
Mon Feb 22, 2016 9:58 pm
Speedtouch wrote:Check the blue temperature sensor and wiring first before condemning the chip!
:D wasn't condemning the chip, I got the car with the engine conversion and chip installed, but the previous owner informed me that since he had the chip in place its always been like that?!? I could of taken his word, but it just seems strange for it to act one way when cold, but perfectly when warm..........so thought id ask if owners with the same engine/chip set up were experiencing the same symptoms, just a process of elimination.
jurassicwadey
Mon Feb 22, 2016 10:02 pm
but will check the blue temp sensor!- would this also cause a slightly juddery start up?
Tue Feb 23, 2016 9:57 am
Open the ECU lid and find out which chip you have - some are better than others in regards to cold start map, etc.
zaust
Zone day release
Tue Feb 23, 2016 10:26 am
after you have checked the temp sensor I would also have a look for a small leak around the inlet side. A small gap can close quickly when warm.
M30 Tech 1 Touring on gas.
aimlessrock
Tue Feb 23, 2016 8:26 pm
zaust wrote:after you have checked the temp sensor I would also have a look for a small leak around the inlet side. A small gap can close quickly when warm.
as above, this sounds more like an air leak.
E30 320i Convertible (1989)
190 Mercedes (1988)
