1602
chh137
Post Fri Feb 19, 2016 10:19 pm
Trying to get info for a 1602 I'm interested in buying,off bmwvin site ,but it doesn't appear to like vin No. I'm putting in (3561329) .
Can anybody help pleasea˜€
handpaper
Post Sun Feb 21, 2016 12:28 am
Dunno if it helps, but realoem recognises it :
http://bmwfans.info/vin/decoder?vin=3561329
Post Sun Feb 21, 2016 10:24 am
RealOEM does not give you original spec which I guess is what the OP wants. It's purely a parts DB.
jimbom30cab
Tech 1 freak
Post Sun Feb 21, 2016 10:37 am
handpaper
Post Sun Feb 21, 2016 1:25 pm
Bookmarked.
Many thanks.
Post Sun Feb 21, 2016 2:08 pm
There are several online VIN decoders, but when one failed to work for a period of several hours a couple of weeks ago, all the others failed as well, so it looks like they all use the same database, which is where the basic problem must have been.
If this VIN doesn't get results for the OE build spec. on one site, then unfortunately, it's unlikely to get results on any of the others as well.
m3dtm
Post Sun Feb 21, 2016 4:28 pm
Is there also a site where you can check if your car is a Cecotto or not?
John
Post Mon Feb 22, 2016 10:55 am
m3dtm wrote:Is there also a site where you can check if your car is a Cecotto or not?
John
Trusty BMW dealer vin check works every time. Though there should be plenty of other identifying clues !
