Hi,
I have central locking on my car but when I lock the drivers door the passenger door doesn't lock. If I turn the key from neutral to the lock position a few times it seems to go down.
Any ideas on where to start with troubleshooting.
Thans.
E30 Cabriolet door lock
Lubricate the linkage, adjust the position of the lock motor position and replace the L shaped alloy piece on the back end of the lock barrel, which is only available as part of a lock repair kit. If you're into bodging, you can clean up any wear ridges on the alloy piece, and squeeze the steel fork that engages with it together a small amount.
