M52 e30 shopping trolley
mark_i
Post Sat Jan 23, 2016 7:31 am
apart from the inlet manifold and sump from an M50, any other parts worth getting to put on an M52...?
also, what is the best way to get access for removing a Clio servo booster with the Renault engine still in the bay?
JoshH
Post Wed Jan 27, 2016 9:10 am
Clio servo actually comes out inside a Clio. You drop the pedal box, disconnect master cylinder inside the engine bay and get it out. Many hammers were used on various bits in the way (in a scrap yard) and we got one out in about 10 minutes.
Add an M20 flywheel to your list, machines down to about 5.5kg :)
