Hi need some help guys I'm using an early e28 gearbox with my b35 in a facelift convertible, need some help with which linkage to use as having problems fitting a 325I linkage.
The gearbox I'm using originally used the old plate type linkage so what's the best solution?
Early e28 box in facelift which linkage?
BMW_E30vert
motormanmick
Hello bmw_e30vert, did a little digging for you and found this info, also through google translate, has a few gearbox linkage options, you can always pm them too, hope it helps, cheers.
https://translate.google.com.au/transla ... rev=search
look under - 335i Conversion instructions, then - transmission and shift linkage
