Hi all, hope we are well? I'm wanting to install an autochanger into my E30. Years ago when I had them I always had them fitted in the boot under the parcel shelf area, however lately I have seen some people with them fitted in the glove compartment. What's the pros and cons of each please? What's involved in running it to the boot of a 4 door saloon? What has to be removed in order to run the cable in each scenario? Thanks in advance, kind regards
Mr-Lachs
Autochanger Location
- Brianmoooore
Cons are obviously the loss of most of the glovebox.
Easiest way to run cables to the boot area is to remove both centre consoles (easy) and the rear seat base (even easier), then run the cables on top of the transmission tunnel, threading it under the last short section of carpet, then across the rear seat pan, back above the wheel arch and into the boot.
The 'correct way', as shown in the BMW dealer installation instructions is along the LH inner sill, but I've come across many cases where this has been ignored, and the cables run back the middle instead.
Hi Brian my sincerest thanks for the quick and thorough response I really appreciate it. I'll stick to the boot as I had at the time and use your method there
hope you are keeping well.
Kind Regards
Mr-Lachs
Kind Regards
Mr-Lachs
Mr-Lachs
1988 BMW E30 325iSE Auto, 4 Door, Lachs Silver (Fair Weather Machine)
2012 Vauxhall Insignia 1.8 Exclusiv, Technical Grey, (The Daily)
