Hello,
I want to swap my drum brake with disc brake type rear axles.
Does the rear bearing is same or different? Or does allbdisc brake is abs?
I found 2 different bearing size at etk/realoem which should I use?
Thank you
Markus
which rear bearing?
markus_74
gromgsxr
ABS rear discs have bigger bearings than non abs disc arms
BHadley
I thought the drum brake trailing arms where not compatable with just bolting on disc brake type parts?
As in you need the whole trailing arm from a disc brake rear axle and work from that?
BenHar
Rubbish.gromgsxr wrote:ABS rear discs have bigger bearings than non abs disc arms
The only difference between ABS and non ABS is the toothed ring.
Ben
BHadley
Wha? There are two different sizes listed when i checked!
Non abs seems to be smaller than the abs type for disc brakes trailing arms
See link....
http://www.e30zone.net/modules.php?name ... c&t=261087
See link....
BenHar
That's disc and drum.slideout318i20 wrote:Wha? There are two different sizes listed when i checked!
See link....
It's a common misapprehension that non ABS=drum but that's not the case.
Ben
Same misconception applies when buying braided brake hoses as well. They are usually listed ABS/non ABS, when it should say disc/drum. Many have ended up two hoses short because of this.
pianist
I think you do need whole trailing arms as the drum ones don't have mounting points for calipersslideout318i20 wrote:I thought the drum brake trailing arms where not compatable with just bolting on disc brake type parts?
A disc brake set up cannot be bolted on to drum rear trailing arms.
