So just after going over 100k on the clock the radiator (original) sprung a pretty admirable leak. Planning to drop a replacement in over the holidays.
Before I pay through the nose for an OEM spec through Cotswold or similar, does anyone 1) have a make they would recommend and 2) a supplier for it?
Car is a 1990 325i - M20 all original specs.
Any advice much appreciated!
Recommendations - new radiator 1990 325i M20
Supafly
I believe BEHR is the OEM manufacturer, Should only cost a little more than £100 for a new one online.
Supafly
I've just had a quick search using P/N 17111712823 and not been able to find any BEHR units. This is for a non air conditioned car.
Might have to wait and see if someone else can help....
Nightshift
Thanks Supafly. Will see if I can find a UK supplier...
Mitchen
Although Behr make all variants for BMW, trying to find a Behr radiator minus the BMW badge only leaves you with a few select types. I searched high and low for months for one for my non air con, auto M20.. and just drew blanks.
In the end I settled for Nissens, who are a very good brand!
Nightshift
Thanks for the advice Mitchen.
Found Hella radiators (manufactured by BEHR - same company essentially) at buycarparts.co.uk, in case anyone else is looking.
http://www.buycarparts.co.uk/bmw/3-salo ... 0&to=10000
BHadley
Wow your above link prices are high!
Car parts for less is your best bet, use the discount codes too (it's all on the webpage when you go on it)
Link with prices;
http://www.carparts4less.co.uk/car-radiator
Link with prices;
