Water leak
- theretroking
Discovered a water leak in my Baur few weeks back seems that the drivers footwell was damp.
felt around to see if i could feel any drips above the accelerator pedal but was dry.
Left a towel there to but just seems to get wet around the sill area
of the carpet.
Havnt driven the car for a while either.
Anyone have any ideas.
of the carpet.
I don't know much about e30s yet as i only got one on the weekend but my years panel beating say you should check the winscreen seal, the door membranes behind the door card and the heater box depending on what it's like on a e30
- theretroking
Just thinking could it be the door seal
Carpet out, dry everything and sprinkle some talcum powder around the area - any water coming in will leave streaks in the powder which should point towards its source.
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
- theretroking
Cars parked on level ground, if that helpsjcm325 wrote:+1 for the door seal has caused me a similar problem on mine....is the car parked flat/nose down/nose up? may help with diagnosis......
- theretroking
Elephants trunk, where and how do i check, please.jslot wrote:Maybe also check the 'elephants trunk' scuttle drain
If the carpet is wet it will need to come out to dry it properly so you could save yourself hours/days/months trying to guess where the water is coming in...
jmc330i wrote:Carpet out, dry everything and sprinkle some talcum powder around the area - any water coming in will leave streaks in the powder which should point towards its source.
James
'91 325i Sport
'91 325i Sport
- theretroking
Just noticed the water seems to be coming from above the brake pedal (auto Model) would this be the elephant trunk if so whats shoild i do.
- Brianmoooore
No, that would be rust, unless it's something silly, like a displaced grommet.theretroking wrote: would this be the elephant trunk if so whats shoild i do.
Elephant's trunk water comes from the heater vents.
- theretroking
Had another look today the water seems to be coming in by the drivers foot rest, would that be the elephant trunk issue, also the car has not been driven for several months so not coming from under the car.Brianmoooore wrote:No, that would be rust, unless it's something silly, like a displaced grommet.theretroking wrote: would this be the elephant trunk if so whats shoild i do.
- Brianmoooore
It's coming in where it's coming in. Get some talcum powder spread around, and the trail'll lead right to the leak.
