Wipers not intermittent
jcm325
Post Thu Nov 26, 2015 10:14 pm
Hello all another day another problem,my wipers work absolutely fine on normal speed/fast speed but when I select intermittent wipe they run at normal speed?obviously this is wrong does anybody have any ideas why? I have had the motor out and cleaned up the contacts and regreased everything which has cured the stuttering issue....I.m thinking this could be an issue with the stalk?
Any help as ever would be great...
motormanmick
Post Fri Nov 27, 2015 3:14 am
Stalk is 3 position, if it's not working on intermittent due to open circuit it would most likely do nothing. There is a relay that times the intermittent on your wipers, it is possible that that is the issue. 1989 325i electrical trouble shooting manual link below may be of use to you.
http://www.armchair.mb.ca/~dave/BMW/e30/e30_89.pdf
E30 zone wiki says the intermittent wiper relay is located in the fuse box, link to wiki on wipers below.
http://www.e30zone.net/e30zonewiki/index.php/Wipers
Bentley e30 manual link is on this site, that will have info on wipers as well, is American but has heaps of useful info, happy hunting, cheers
http://www.r3vlimited.com/board/showthread.php?t=164030
