Central locking woes
SukhSingh
Post Wed Nov 18, 2015 4:46 pm
Hi guys I need advice on someone to fix the central locking in my cabby, I'm in the hitchin Herts area. Thanx in advance.
Post Wed Nov 18, 2015 11:45 pm
Some indication of what's wrong with it would help!
Yeti
Post Fri Nov 20, 2015 7:26 pm
yup could lend a hand if needed mate just got mine working im near Milton Keynes. are you sure it has it? the wiki as above saved my ass found door pin in the door socket completely corroded away :/ had to solder in a bypass sort of thing.
motormanmick
Post Fri Nov 20, 2015 9:43 pm
Brianmoooore wrote:Some indication of what's wrong with it would help!
Mine broke the little cast arm off the back of the lock in the door, there can be quite a few different things happening, we can't help you till you help us, cheers.
