Post
Sun Nov 15, 2015 10:47 am
There's no stereo connected up in the pics., so the short answer is no, BUT, if the stereo is connected as BMW is intended (rarely happens), then the knobs should be back lit when the lights are on, irrespective as to whether the stereo is turned on.
Again, if connected as BMW intended, the stereo should only work when the ignition is on, but I, and I suspect many others, rewire it so that it can be listened to with the ignition off and the car parked.
An automatic electric aerial was available for saloons and cabs., and stereos for these have an extra wire coming from them, connected after the on/off switch. This wire provides a signal for the aerial to extend, and can also be used to turn on auxiliary amps.
If the stereo is connected wrongly, with a live power feed (the red/green) connected to this wire, the stereo will be permanently on.
