SPECIALIST required- restoration of my E30...please advise
gillsl500
Hi guys,
As the title says, I'm after some much needed advice about restoring my E30 325i convertible, well actually I'm after a service that can do everything I need doing to put the car right!
I'm pretty certain I'm going to need the following put right on the car.
1) rust, I.e arches, fabrication and welding
2) maybe a full body respray
3) engine and auto box re build (don't want a manual box and not fussed with speed from a engine conversion)
4) engine bay tidying up
5) all external rubbers and trims replaced
6) setting it on air ride suspension/advice on wheel
There maybe more things that need doing, but the list above gives you an idea.
So question is, can anybody recommend some one who can do all that for me in one place?
Ideally in the midlands as I'm based in Telford. But if not then I suppose I can go where ever needed.
Many thanks for taking the time to read the post.
HairyScreech
Your not going to find one place that can do all of that, You are at least looking at an engine builder, a gearbox recon shop, a body shop and some kind of custom place to do the stance bits.
aimlessrock
I can put you in touch with a good engine builder and bodyshop in Manchester (they can both work on the car at the same time) but this sort of quality work does not come cheap.
PM me if i can help.
E30 320i Convertible (1989)
190 Mercedes (1988)
190 Mercedes (1988)
Greenun
It's going to cost close on £1500-£2000 for a full respray if you want a top notch job, this project will need deep pockets for all that work.
I bet all the rubbers/trim won't be cheap, the stealers quoted me £100 for a sunroof seal
gillsl500
Cheers for the input so far guys
Andyboy
- Alpina Colada
And the rest! Try doubling that for a proper job including arches.Greenun wrote:It's going to cost close on £1500-£2000 for a full respray if you want a top notch job
ross_jsy
Where are you getting top notch resprays for £1500-2000? My guess is your top notch and my top notch are two very different things
pierce
Why does everyone think a respray costs £1000-£1500!!!!!!
ross_jsy
Because a blow over chocked full of filler costs that. Full body respray innit
maxfield
My mate owns a bodyshop and will do a £1500 respray, but it is a bit of filler and a blow over. He doesn't like doing it but unfortunately we've all got to make a living.
On the other end of the scale, he's got 4 cars in for bare metal, which do require a bit of welding etc and they're all going to be £5k plus.
elan
What would be a realistic price for a windows/engine/all trims out bare shell respray to a good finish?
I may be looking to do this shortly.
bigbird76
A decent job will cost you 4K+ Its not the paint its the hrs that have to be put in to get the good finish your looking for.elan wrote:What would be a realistic price for a windows/engine/all trims out bare shell respray to a good finish?
Leigh
HairyScreech
Completely. Just sorting the door dings out on mine took 11 hours. I still have to do the sill welding, the shell carry mounts and the bits around behind the tech 1. Expecting at least another 20 hours work to do it properly.bigbird76 wrote:A decent job will cost you 4K+ Its not the paint its the hrs that have to be put in to get the good finish your looking for.elan wrote:What would be a realistic price for a windows/engine/all trims out bare shell respray to a good finish?
Leigh
Paying someone to do that would be 5x the value of the car.
elan
So is £6K reasonable to strip the car to bare shell, address rust areas and paint?HairyScreech wrote:Completely. Just sorting the door dings out on mine took 11 hours. I still have to do the sill welding, the shell carry mounts and the bits around behind the tech 1. Expecting at least another 20 hours work to do it properly.bigbird76 wrote:A decent job will cost you 4K+ Its not the paint its the hrs that have to be put in to get the good finish your looking for.elan wrote:What would be a realistic price for a windows/engine/all trims out bare shell respray to a good finish?
Leigh
Any recommendations for places around the London area?
my e30 body resto cost me 6 grand 6 years ago
Kos
Don't forget that good paint and laquer wil be double the price of cheap materials
That all depends on how much and where the rust there is!elan wrote:So is £6K reasonable to strip the car to bare shell, address rust areas and paint?
You stripped your car to a bare shell yourself which saved quite a bit on labour costs and yours was not as badly rusted as some can be.Simon13 wrote:my e30 body resto cost me 6 grand 6 years ago
87mtech27
Wide range of figures being thrown around
Kedge
Retropower do complete (bare shell, engine, transmission etc etc) restorations over near Hinckley, dare say it'll be expensive though!
A bit like it'd be getting quotes in the real world then!!87mtech27 wrote:Wide range of figures being thrown around
true but it needed attention in all the classic e30 rust spots, but i got the car done before it was really bad in certain areas. Point is they needed this sort of work 10 years ago plus!bss325i wrote:You stripped your car to a bare shell yourself which saved quite a bit on labour costs and yours was not as badly rusted as some can be.Simon13 wrote:my e30 body resto cost me 6 grand 6 years ago
I changed every bolt on panel also as they all had rust in certain points and painted everywhere! engine bay the shuts the boot the lot
The costs must be way more now i bought from the dealer brand new wings for £100 each, sunroof panel £100, bonnet £200 then 2nd hand doors and bootlid for about £50 total.
I can keep going!
Yep. Wings are nearly double and sunroof panels are over three times the price now!Simon13 wrote:true but it needed attention in all the classic e30 rust spots, but i got the car done before it was really bad in certain areas. Point is they needed this sort of work 10 years ago plus!bss325i wrote:You stripped your car to a bare shell yourself which saved quite a bit on labour costs and yours was not as badly rusted as some can be.Simon13 wrote:my e30 body resto cost me 6 grand 6 years ago
I can keep going!
elan
I can see how the costs can mount up. I suppose its partly about weighting up the restoration costs with what it might be worth in the end.
The other thing to remember is that it is absolutely pointless bolting tatty, rusty, crap brackets, fixings, suspension, steering, mechanical parts etc, to a freshly restored shell. All of that mounts up as a few bits are now NLA so you are into having the originals restored in themselves. All of that will mount up to well over your welding costs alone!elan wrote:So is £6K reasonable to strip the car to bare shell, address rust areas and paint?HairyScreech wrote:Completely. Just sorting the door dings out on mine took 11 hours. I still have to do the sill welding, the shell carry mounts and the bits around behind the tech 1. Expecting at least another 20 hours work to do it properly.bigbird76 wrote: A decent job will cost you 4K+ Its not the paint its the hrs that have to be put in to get the good finish your looking for.
Leigh
jimbom30cab
- Tech 1 freak
£6k will probably get a car stripped, welded and painted. Don't expect a "thorough" job though, it will be a bing bash bosh job's a good un type job.
On the other end of the scale, i'm doing a full nut and bolt resto and getting towards the end of the work now, with the current spend working out about £15k (plus cost of the car).
Probably will cost about £20k when done as i've done a lot more than really needed...but I want it to be up there with the best examples in the world.
