Gasket change fail? HELP!
BEERBOY123
Thu Oct 22, 2015 7:59 pm
Changed valve cover gasket/bolts on M42. Now turns over but doesn't start. I don't want to try too many times for fear of wrecking it. There is a vague burning smell too.
I take it this is not normal! Help!!!
Two headblenders, couple of bags of MC Hammer, 5 litres of FFF, a 48ft bastard, a box of jumped-up custard and some soggy chimps
DHFiS
Thu Oct 22, 2015 8:23 pm
plug leads connected in the right order?
BEERBOY123
Thu Oct 22, 2015 8:38 pm
I think that must be it. What order please!!!
Plugs under 50mm of oil?
BEERBOY123
Thu Oct 22, 2015 8:51 pm
Sorted! What an idiot I am - confusing firing order with actual order.
Embarrassed...
DHFiS
Thu Oct 22, 2015 8:59 pm
Cylinders are numbered 1 to 4 with 1 at the front and each coil in the pack on the wing has a number from 1 to 4. I will leave it to you to work out which coil goes to which plug.
If you use Google Images and the search term 'M42 firing sequence' you will find some pictures.
As Brian says, check the plug leads are not sitting in a pool of oil.
If you are Ratch is this going to turn out to be a joke?
BEERBOY123
Thu Oct 22, 2015 9:02 pm
No, honestly I am not Ratch. I will check plug leads.
Is there some way of proving I am NOT Ratch for God's sake!!! He's competent. I'm not.
Why would plug leads be sitting in oil though?
BEERBOY123
Thu Oct 22, 2015 9:07 pm
Will my attempts to start with plugs in the wrong order have done any badness?
DHFiS
Thu Oct 22, 2015 9:12 pm
BEERBOY123 wrote:Why would plug leads be sitting in oil though?
Because you had an oil leak?
BEERBOY123
Thu Oct 22, 2015 9:13 pm
No, they are dry.
ross_jsy
Thu Oct 22, 2015 9:14 pm
BEERBOY123 wrote:Will my attempts to start with plugs in the wrong order have done any badness?
No.
