Starting issue...
Gavla
Sun Oct 18, 2015 8:55 pm
Last night I struggled to get my 86' 325i started... turning over but not firing into action straight away...after 3 or 4 tries it fired up but there was a "pop" sound from under the bonnet...drove fine...
Today nothing...turning over but no matter how many times I tried during the course of the day it did not fire into action...
Any help and advice appreciated...thanks :D
Sun Oct 18, 2015 10:02 pm
You'll have to narrow it down a bit further than that!
Sparks at plugs?
Fuel pressure in rail?
Fuel pump running when cranking?
Plug tips wet after cranking?
Gavla
Mon Oct 19, 2015 9:31 am
Thanks Brian...will get onto it when I have a chance and report back...
E30M3EVO
Mon Oct 19, 2015 9:48 am
I've had a similar issue and turn out to be a faulty fuel pump. Fuel pump is under the rear seats on the driver's side.
Gavla
Mon Oct 19, 2015 2:00 pm
Don't know when i will get a chance to check the list Brian gave me...
However, does the fact that when I tried this morning it fired up narrow down the possible problem...?
@ E30M3EVO... that was my initial thought...
Gavla
Tue Nov 03, 2015 8:16 pm
FYI
Ended up sending it in to get a diagnostic read out...all ok...except the ignition coil so that is being replaced and will hopefully be ok...
