where exactly are the sill drain holes in a facelift cab?
povertyspec
..and whats the best way to ensure they are clear. just redone my wheelarch and extensive gandering hasnt located them on the many times undersealed sill. should they have any flaps or bungs fitted?.
HairyScreech
Looks to me like front, rear and centre where the indents are.
SilverShadow
- Hartge Crew
theres also some located in the hood compartment that lead to the above sills.
povertyspec
so i need to trace three equidistant holes in the underseal and drill them clear carefully?. 10 minutes with a torch revealed no trace of them last night.
povertyspec
ahhh and they are actually on the seam!!??????? i think i see now.
povertyspec
right, ive found them, slightly slotted holes on the back of the sill seam. unfortunately mine were full of underseal.they are now clear and dry. A job well worth doing.
Gert_8
- Location: In your back passage faster than a rat up a drainpipe!
Put a pic up, please!povertyspec wrote:right, ive found them, slightly slotted holes on the back of the sill seam. unfortunately mine were full of underseal.they are now clear and dry. A job well worth doing.
Gert_8
I want to make sure they are not clogged...
