As above, I'm sitting on 139k miles and the sticker in the bonnet says to replace the timing belt at 143k.
Car needs a service and the handbrake fixed so was thinking of putting her in and getting the timing belt done also whilst I have the coin to do so. That way she's raring to go for the spring / summer....
Opinions appreciated
Right time for timing belt replacement
stonesie
DO IT!!
you dont want to be doing all that work in only 4k's time so i would hit it all in 1 go then its sorted for the next 5 years or however many miles a belt is rated for on your car
Definitely do it! If the 143k on the sticker was based on the official belt replacement interval, then it should have been done several thousand miles ago. Change the tensioner pulley and water pump as well.
paule30
Its a no brainer mate, do it ASAP and try to get hold of dealer belt and tensioner, replace both
Paulo
Paulo
Razza
Ok will get on to it asap, what price would I be looking at for the aforementioned work?
