My ECU needs replacing on my 1989 318i
I have found one on EBay with the same part number which is 0 261 200 157 (Brown label)
The seller states that it is from a 316i/318i. Apart from numbers will this just be a straight swap from my current ECU?
Thanks in advance
E30 ECU
Andyboy
- Alpina Colada
318i and 518i ECU's are interchangeable as long as they are M40. A 316i ECU will have the wrong ignition timing.
I have a good M40 1.8 ECU here, £25 posted.
157 is correct for a 1.8 engine. The equivalent ECU programmed for a 1.6 is a 174.
HairyScreech
Surely that is then just a case of swapping the chips over from the 318 to the 316 ECU?
Same as with the M50TU EWS and non EWS ECUs?
SAP1
Thanks for the input, Brian you da man thanks
