My friend had e36 m40 318i, he said that his ecu bosch 0261200520 is broken, so he tried to use another ecu, same number and specs except the one with stamp dme 3 unit and other motronik 2 unit and he got it all from abroad not local ecu it is about 5 ecu.
The problem is all ecu will run the engine about 2 minute before engine die and flood the combustion room with fuel. He tried again to another healthy car and the result is same.
He has check with scanner and both ecu has same spec and menu.
What is wrong here?
Thank.in advance.
Markus
ecu problem? e36 m40
markus_74
