Sunroof
jasso
Post Tue Aug 18, 2015 10:53 pm
As many of you may know I have got my e30 back from the paint shop and am now fitting it up, I have fitted the sunroof tracks on both side but they are not in line with each other any ideas how to resolve this??
Post Wed Aug 19, 2015 3:26 pm
Remove the motor assembly (which will allow the cables to slide), set the tracks on both sides to full tilt, use the switch to set the motor to full tilt, then bolt it up again.
jasso
Post Wed Aug 19, 2015 4:34 pm
So remove the 4 10mm bolts that hold the motor up??
**BANNED**
Post Wed Aug 19, 2015 5:53 pm
[quote="Brianmoooore"]Remove the motor assembly....../quote]
Er...yes!
:mad:
Youth is wasted on the young.
jasso
Post Thu Aug 20, 2015 6:19 am
daimlerman wrote:
Brianmoooore wrote:Remove the motor assembly....../quote]
Er...yes!
:mad:
Got it sorted was the 3 screws to be undone and not the 4 10mm bolts
