Headlight dismantling
Awarded
Post Tue Aug 18, 2015 3:47 pm
I'm dismantling my headlights to give them a refresh, but can't get the adjuster knob off the frame. I can separate parts 5 and 6 in the following diagram http://www.realoem.com/bmw/enUS/showpar ... Id=63_0072
How should they come apart? I tried using a socket and spanner but the socket is slipping over the nut (part 5). From the diagram it looks like they might be a push fit but pulling apart didn't get me anywhere either.[/list]
Cloggy Saint
Post Tue Aug 18, 2015 5:10 pm
Release #5 from the headlight frame by twisting it 90 degrees and if the threaded bolt has been freed from the cup it sits in there's no reason to remove #6.
Awarded
Post Tue Aug 18, 2015 7:51 pm
Are you sure that #5 is a twist 90 degree to release part, I say that because many of the other parts are but #5 seems different to those.
I need to remove #6 so I can sand down and re spray the frame.
BenHar
Post Tue Aug 18, 2015 10:12 pm
#6 just pulls off.
Ben
