NEED SOME REAL HELP IDENTIFYING PARTS
Jamiestrutt
Post Thu Jul 30, 2015 10:20 pm
Hi I've got a 318is and I can't seem to find the parts I'm looking for, if anyone could help that would be greatly appreciated as I will purchase from costwold if they have them, the first two are the patches up hoses looks like fuel maybe?
The third and fourth are pictures under the gearbox, needing two new rubbers as one has split, the other is I'm sure they should be an exhaust bracket?
Any help welcomed
Vin - wbaaf92090ee48180
scallyally
Post Thu Jul 30, 2015 10:37 pm
Yes the two broken rubber mountings are for the exhaust retaining arm. Search realoem with the first seven digits of your vin to see the set-up. My rubbers were broken but I believe there were no part numbers and I sourced them from an independent parts stockist.
jslot
Post Fri Jul 31, 2015 8:37 am
It also looks like one of your gearbox mounts has split
DHFiS
Post Fri Jul 31, 2015 9:08 pm
The bodged hose in the 2nd pic look like part of the throttle heater.
I discarded mine. See here
http://www.e30zone.net/e30zonewiki/inde ... ody_Heater
