BMW 318IS Full Restoration - Steering Rack
Jamiestrutt
Post Thu Jul 23, 2015 12:09 am
Hi,
I've just recently purchased an IS and was thinking of changing the steering rack as I found it far too sluggish! I've heard the z3 to be the best to put in, will any adaptations be needed for it to fit or any other that I can use that will have a difference?
Also what else with the steering rack will I need to get?
It's hopefully my project over the winter and more than likely next haha! Any other advice on potential modifications to the car would be greatly recieved!
ross_jsy
Post Thu Jul 23, 2015 12:26 am
The z3 rack is the fastest, but most consider the purple tag e46 rack a better option.
You can use e30 power steering hoses and bend them to suit but I recommend buying pre-made hoses off the zoner DanThe, excellent quality and fit. You will also need some spacers for the rack, and either modify the existing linkage, use a Corsa linkage or Dan also sells a splined shaft, which you use along with 2 e34 steering UJ's. Have a read through the Wiki to familiarise yourself:
http://www.e30zone.net/e30zonewiki/inde ... onversions
