When I pull the indicator stalk down to turn left, the indicator makes a buzzing noise and does not come on. Before I pull it all apart (again) does anyone have any suggestions?
Also I fitted a Nardi steering wheel with an Autotechnica mounting boss. The boss was not very good. The horn wire pulled of after a few days and the pin that sits on a spring and connects to the metal ring on the back of the steering wheel broke off. I repaired the pin and put the original wheel back on. Has anyone had any luck with a boss that mounts a Nardi wheel with out the above hassles? Also has anyone found a boss that has a built in indicator cancel?
turning left indicator buzzing
xavier
